I have the same problem! What happened.?
Okay, after doing some looking, this started after I did the latest upgrade on the Cura software. It has to be a problem with the software update.
In Cura - Have you checked the machine settings for the printer? Maybe they didn't carry over correctly during the update.
I have triple checked the printer settings and they are correct.
When I look at the software, it shows it the correct size and placement on the plate. When it prints, it is completely different.
Edited by SLTeacherI have triple checked the printer settings and they are correct.
Load your model, and then go the File -> Save as... to save a project file. Put it somehwere we can download it (dropbox, google drive, mega) so we can have a look at what is going wrong.
Edited by ahoebenHere is the dropbox link
https://www.dropbox.com/l/scl/AACXxDiUi4azmoY_-2pTkgSJp88tePzgGL8
Let me know what I am doing wrong. I even deleted the printer and reloaded it and brought the file in again. Thanks.
You will have to change the sharing rights to the file on dropbox; only trish***@silverl***.org is allowed to download the file.
Ok, I put it here and see if this works. I don't know why the dropbox will not work. It shows it allows. Try this one:
https://drive.google.com/file/d/1TYkTCjCF_0aJT-3i3OEw_nrTM-1miRC0/view?usp=sharing
Your google drive also requires me to log in and request access from you.
Try it now! I think I have it fixed. Sorry about all of this.
When I load your project (in Cura 4.6 or 4.7 beta), it seems to fit the build plate just fine.
I do have a tip: instead of adding > 100 support blockers, try adding fewer and scale them up. Cura does not deal well with hundreds of individual objects.
Thank you! It is when I go to print that it only prints in the front quadrant. I will try again with the change you suggested.
Thank you so much for the help!!
That is something very different from what the topicstarter reported, so why you say you have the same problem is eluding me.
I don't know what that is. I cant see it.
SLTeacher 0
