Tried using the gcode. It works great but when I choose my material (pla) in cura, the bed temp still stays at 125 degrees C. What should I do?
Check the bed temperature in the advanced settings ("sidebar"). Any value set in the profile(s) for your printer will override what is set for the material.
Mmmm... Doesn't work. Would it have to do with the fact that I am using a Creality CR-10s Pro?
Wait! I tried this, and it works!
QuoteM140 S{material_bed_temperature_layer_1} ;Start heating bed M190 S{material_print_temperature_layer_1} ;Wait for bed to reach temp before proceeding M104 S{material_print_temperature_layer_0} ;Start heating extruder M109 S{material_print_temperature_layer_0} ;Wait for extruder to reach temp before proceeding
I simply put a number 1 for the layer!
- 3 months later...
I think the error is actually in the definition of print or bed on line 2.
Should be BED on line 2:
M140 S{material_bed_temperature_layer_1} ;Start heating bed M190 S{material_bed_temperature_layer_1} ;Wait for bed to reach temp before proceeding M104 S{material_print_temperature_layer_0} ;Start heating extruder M109 S{material_print_temperature_layer_0} ;Wait for extruder to reach temp before
- 5 months later...
This is what I needed to get the final step of my printer with a BLTouch working as intended!
Thanks everyone here! This was awesome! My CR-10 V3 is printing amazing now!
- 2 weeks later...
You don't actually need all 4 lines. This is what I use. Start the bed heating, then immediately start the nozzle heating and wait. Once the nozzle is heated it will proceed to the third line which ensures the bed temp reaches printing temp before starting the print.
This way IF the bed isn't to temp before the nozzle, the third line makes sure the bet temp reaches the set value. If the bed reaches temp first, it just goes on to the next line, which in my case is homing.
M140 S{material_bed_temperature_layer_0} ;Start heating bed to temp
M109 S{material_print_temperature_layer_0} ;Start extruder heating and wait to reach material temp before proceeding
M190 S{material_bed_temperature_layer_0} ;Ensures bed heats to temp before proceeding if it hasn't already
And it SAVES A WHOLE LINE OF CODE! Whoop-dee-doo! 😜
GregValiant 1,318
There is no keyword "material_bed_temperature_layer_1" so it would be ignored. The list of keywords is HERE.
ahoeben 1,965
Cura checks if the start gcode contains commands to heat up the hotend and bed before the print is started. If the start gcode does not have command to do that, CuraEngine adds the three lines (M190, M104, M109) before your start gcode just to make sure that the hotend is not cold before starting the actual print.
If you don't want Cura to add these lines, make sure your start gcode contains lines which have {material_print_temperature_layer_0} and {material_bed_temperature_layer_0} in them respectively. eg:
Super169 0
Thanks a lot.
It works fine, and I have no need to modify the generated g-code anymore!
