In cura go to PREPARE mode (near the top of the screen - a bit left of center).
Then on the next row down to the left you should see your printer. Click that and select "manage printers" button.
Now make sure your printer is selected and select "machine settings". Now you can edit things about your printer. In particular bottom left area should have "g code flavor".
ahoeben 1,602
The Ultimaker 2+ uses UltiGCode by default. With that flavor of gcode, you select what material to use on the printer. The printer also controls the temperatures. If you want to have full access to material settings in Cura (including the temperatures), go to the Machine Settings and change the G-Code Flavor to "Marlin" instead of "Ultimaker 2".
cmjennings72 0
I am having this same issue with 4.6 and I don't see anything labeled "Machine Settings" and when I go into " Settings" it only shows " Setting Visability". I don't see "G-Code Flavor" anywhere where I could enter "Marlin". Please advise.
