Why does Cura think my models are completely solid?
Posted
· Why does Cura think my models are completely solid?
So sketchup specifies which part of every surface faces air and which side faces plastic. This information is stored in the STL file as something called a "normal". Your normals are backwards inside that part. In sketchup you can tell because the surface is gray instead of white. Right click on that surface and select "reverse faces".
If you are new to sketchup I suggest you switch to a solid modeling CAD versus sketchup which lets you create infinitely thin planes. Normal CAD software does not let you do that. Sketchup makes it work to seal up all solids - people often forget to seal in the bottom for example. But if you are a sketchup expert then definitely read the advice in the above link.
Posted
Ah thank you. On a sketchup forum I discovered it was actually the file format it was exported in. The faces were already right-side out, but I appreciate the link you provided.
gr5 2,243
More sketchup tips for future models: https://i.materialise.com/blog/3d-printing-with-sketchup/
