It might depend on how deep the vacuum has to be? Not only the plasticizers might be a problem, but also water and plain air. For example nylon absorbs a lot of water very quickly, which means it goes through easily. Also, some plastics are not oil-tight nor airtight: oils and solvents might seep through, as well as atmospheric air.
And what if it fractures? How big will it be, and how strong does it have to be? And what if it shatters: can that do harm or not? Big objects need to be incredibly strong.
If it has to keep its vacuum for a longer time, I think you would best go for metal or glass. If it is actively kept under vacuum by a pump, I think any reasonably strong plastic might work?
Your biggest problem might be how to print it airtight? Normally prints have huge amounts of tiny voids, canals, bubbles,... You will have to print very slow and in very thin layers to get it watertight, and on a single nozzle setting (no dissolvable supports).
I once tried to print a filter for my vacuum pump, first at default settings. To test it, I put it under pressure with tap water, but the water jetted out via lots of tiny holes. After printing again slow, cool, and in the tinnest layers possible, it is now watertight, and it seems reasonably airtight too. But the rest of the system isn't: silicone-tubing is not vapour-tight at all, and not oil-tight either, and the pump probably isn't too, so I can't really test my filter alone.
SandervG 1,521
That is a good question! I will ask around.
