Retraction from prime tower to part
willryan3
Posted · Retraction from prime tower to part
I have been getting some "zits" on the outside corner of my print (side facing the prime tower) and was wondering if I need to up my retraction settings or if there are some other settings that would help. I am currently printing using PET+CF with settings of 7.5mm distance, 30mm/s speed. Please let me know!
Thanks, Will
    Hello there,
    2 things I have in mind. First you would have to carefully observe if the material is oozing when the print head is moving from the prime tower to the print. If so, you can increase retraction distance and speed and/or decrease print temperature. Since I have no experience with CF material I can't tell if your settings are right or not.
    Secondly, why just print without the prime tower?
    Good luck!
    53 minutes ago, Framar said:
    Hello there,
    Good luck!
    Upping my retraction settings now. As far as the prime tower I was using it to prevent these strings but if I get my retraction down does that eliminate the need for the prime tower?
    In addition I would place the tower closer to the printed object to avoid such long travel moves in between.
    Good idea, I did not know you could do that. Thanks!
    Posted (edited) · Retraction from prime tower to part
    You can enable coasting in cura it will stop extruding slightly before wall ends that will cause that extra filament to stay inside the walls. Also if you are using a custom printer or a marlin/repetier based printer try to calibrate the extruders step/mm setting (google) It is easy to do because some cheap printers dont give attention to these calibrations
    Edited by DarRAven
    typo
    Sounds great. I will give that a try.
    Thanks
    Thank you all those who helped! After using coasting, moving tower closer and a few other tweaks the part turned out great. Appreciate it,
    Will
        • 4 replies
