Greg, thanks for the reply. I will try your suggestion this morning. My description wasn't adequate. Last night I remembered I also have Prusa slicer on my computer so I sliced the same object wih it and the printing location was normal in the center of the bed. I also reloaded Cura 4.4.o and now have the same problem when slicing with 4.6.
When using 4.6 the printer lays down a strip of filament very near the left edge of the bed and then comes back to the left front corner and start printing my object. The Z position appears to be normal but the object is partially printed on the corner of the bed and partly in the air to the left of the bed.
Start of my g-code file
;FLAVOR:Marlin
;TIME:2209
;Filament used: 1.35208m
;Layer height: 0.2
;MINX:-7.739
;MINY:-34.097
;MINZ:0.2
;MAXX:7.739
;MAXY:34.097
;MAXZ:6.2
;Generated with Cura_SteamEngine 4.4.0
M140 S60
M105
M190 S60
M104 S200
M105
M109 S200
M82 ;absolute extrusion mode
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G92 E0
G92 E0
G1 F1500 E-6.5
;LAYER_COUNT:31
;LAYER:0
M107
;MESH:TX Tray Latch v1.stl
G0 F6000 X-5.763 Y4.303 Z0.2
;TYPE:WALL-INNER
G1 F1500 E0
G1 F1200 X5.761 Y4.303 E0.38329
G1 X5.763 Y4.303 E0.38336
G1 X5.763 Y0.892 E0.49681
G1 X5.763 Y-4.303 E0.66959
G1 X-5.761 Y-4.303 E1.05288
G1 X-5.763 Y-4.303 E1.05295
G1 X-5.763 Y4.303 E1.33919
G0 F6000 X-5.363 Y3.903
G1 F1200 X5.363 Y3.903 E1.69593
G1 X5.363 Y-3.903 E1.95556
G1 X-5.363 Y-3.903 E2.31231
G1 X-5.363 Y3.903 E2.57194
G0 F6000 X-4.963 Y3.503
I sent the whole file to a friend who has the same p;rinter and is using 4.6 and I will hear from him this morning.
GregValiant 1,330
A picture is worth a thousand words. Do you mean it's angled off the bed somehow? Air printing in the left front?
If the bed is level I don't understand how it could do that. I installed 4.6 and now 4.6.1 and there haven't been any issues with the 3 Pro.
Create a gcode file of any model using - Cura 4.6, .2 layer height, with a skirt for bed adhesion. Open the file in Notepad and scroll down until you find a Z value. It should look something like this:
G1 F300 Z0.4
G0 F4500 X75.844 Y52.594 Z0.4
;TYPE:SKIRT
G1 F300 Z0.2 ;This line is the "drop down" to the working height.
G1 F1500 E0
G1 F3000 X76.798 Y52.659 E0.03254
I had a situation where it appeared that my bed had warped. It turned out that I had been adjusting the left front and right rear screws excessively and the bed had become bowed from the uneven pressure of the leveling screws. I took the glass off the bed and using a small block under the nozzle (about 5mm high), I leveled the bed with no build surface on it. That fixed it.
