This is a problem I'm having with my Ender 5 and CURA 4.5. Nothing I have tried works. I'm interested to see if you can get it to work. Good luck!
GregValiant 697
There are 4 Pause at Height scripts in the Cura extensions. One is listed for Repetier (which I think the MonoPrice printer uses). The one that seems to work with the Ender 3P/Marlin is simply called Pause at Height. It inserts this code
;TYPE:CUSTOM
;added code by post processing
;script: PauseAtHeight.py
;current z: 5.2
;current height: 5.0
M83 ; switch to relative E values for any needed retraction
G1 F300 Z6.2 ; move up a millimeter to get out of the way
G1 F9000 X190 Y190
G1 F300 Z15 ; too close to bed--move to at least 15mm
M104 S0 ; standby temperature I would change this line so the Hot End doesn't cool down
M0 ; Do the actual pause TO RESUME you must click the button on the LCD
M109 S215 ; resume temperature
G1 F300 Z6.2
G1 F9000 X85.054 Y112.572
G1 F300 Z5.2 ; move back down to resume height
G1 F3000 ; restore extrusion feedrate
M82 ; switch back to absolute E values
G92 E749.35974
From what I can see it does everything you would want it to...Lift, get out of the way, wait for the filament change, get the temp up to what it was, go back to where it belongs, and reset the extruder in case some filament was extruded during the color change. A nice tidy bit of code that should work with the Ender 5, but will not with JGord's MonoPrice (Repetier doesn't support M0 as a pause code).
so, your saying I have to use the pause at height repetier in cura? Also, thank you for the support.
GregValiant 697
I'm saying I hope so. Good Luck with it. There is more information available if you do a search for "Pausing" +Repetier. There is also a little bit of information on the MonoPrice site.
- 1 month later...
I have a similar problem The pause at height doesn't show up in the G-code script. At least I can¨'t find it and the printer doesn't pause.
Cura version 4.6.1
Using layer height
Artillery Genius
GregValiant 697
Whether the printer understands the codes or not (dependent on the firmware) the pause code should show up in the gcode file. The pause plugin named "Pause at Height (BQ printers)" only adds an M24 to the file. The others add short routines with more flexibility like maintaining the temperature and parking the head. I'm using 4.6.1 also and the code shows up in the files.
17 minutes ago, GregValiant said:Whether the printer understands the codes or not (dependent on the firmware) the pause code should show up in the gcode file. The pause plugin named "Pause at Height (BQ printers)" only adds an M24 to the file. The others add short routines with more flexibility like maintaining the temperature and parking the head. I'm using 4.6.1 also and the code shows up in the files.
I will try again and let you know. Thnx
- 2 months later...
Hi, I have the same issue with my Artillery Genius and Cura 4.6.1, with some scripts I can't pause the printing for change the filament, with "Pause at height" it is the more close script, but the machine only stop 5 seconds like @jgord2006 mentioned, anyone know how to fix it? Thanks
3 hours ago, hpsaturn said:Hi, I have the same issue with my Artillery Genius and Cura 4.6.1, with some scripts I can't pause the printing for change the filament, with "Pause at height" it is the more close script, but the machine only stop 5 seconds like @jgord2006 mentioned, anyone know how to fix it? Thanks
I found the solution.
Take a look here:
https://www.thingiverse.com/thing:4251390
GregValiant 697
Are you refering to one of the Pause-At-Height plug-ins for Cura?
Edited by GregValiantLink to post
