Two thoughts:
1) Modifying STL files for these kind of design changes is notoriously hard in most applications - far better to work from the original CAD files if possible, but this Thing doesn't include those
2) Does anything on the other plate need to change if you make the top plate deeper? Don't any of the standoffs need to engage the LCD board (which is now going to be further away?). Or what about the rotary encoder... doesn't that need to mount higher up now, to still reach the top and poke through?
illuminarti 18
Keep the SD slot the same distance from the back?
