No errors.... while it was printing, I was scraping off PVA material from the top of the smaller bowls. I'm guessing that I pushed the table down and it started printing in mid air. I was bored 😞
How about the PVA over extruding on the bottom of the bowl causing the dug out defect on the print? I tilted the next print and it just moved the defect to the opposite side of the bowl.
SandervG 1,518
Hello, what was the rest of the model suppose to look like? It looks like a clean cut, and no gradual under extrusion. Did your display give you any error or other message? Did your filament get caught in a knot?
