GregValiant 1,319
You might try changing the line width also. It's usually set to the nozzle diameter but can be different. Try .6 line width and bump the flow rate % a bit. If the top cone had steeper sides the individual lines might bond instead of falling into the center.
TomB19 0
Quick follow-up.
This bellows doesn't move very often so I am thinking of using PETG as a backup, at 0.08 or 0.12 layer height with spiralize. I don't know how long it would last but it might be worth a shot.
