There you go.
Thanks for the file, I sliced it and the gcode looks fine.
Could you please attach one of the demo gcodes that prints OK to this thread?
- 1 year later...
I have exactly the same problem. Is there a solution found yet?
It starts feeding the pla wherever it stops last time, so even when its 3cm above the platform. So it seems it doesn't find its zeropoint.
GregValiant 698
Post one of your gcode files that you made and that doesn't work. There is supposed to be a routine that runs at the beginning to initialize all the axes. If it isn't there then it may be an easy fix.
wineglass, that's mine, it prints in the corner in almost 1 spot, like it's trying to print a part outside the platform.
The rocket came with the printer and turned out well.
1 hour ago, CowboYvar said:it prints in the corner in almost 1 spot
It looks like you have the "Origin at center" options set in the Machine Settings (see the Printers pane of the Preferences). That option should NOT be checked for your printer.
1
Really thanks, that worked! That was the only thing where I thought "This is set right!"😅But no!
obewan 21
please attach a cura project file( file/save)
Edited by obewanLink to post
