Mari, thank you for the help. If you preview line by line from the build surface up, you will see the bottom layers, and then the sides build to the point in my settings at layer 140 the flat surface going into the cave appears. there is only empty space under that surface and the print fails. I hope you can see from my picture.
Edited by richgWhen I use infill, it fills the entire cave. My question originally was< Is there a way to limit the infill. Could I have infill up to layer 139 and not beyond? Or could I have infill only under the unsupported floor?
Edited by richgadditional info
I see, Thank youMari.
... but still wondering what setting you are using
You were correct, I though I had seen a photo where the entire area inside the outer shell was open space. I am Technology challenged.🤕
Happy Printing...
Mari 32
Clarify things, make a screencapture and point out your "problem". I opened the file in cura, had to scale it to 2.5% to fit my buildplate!
Can't see why it is not possible to print... cave is open, doesn't change with high or low infill-percentage... and since it is flat on the buildplate there is no need for support...
