Slicing a box ends up as a brick. Cura 4.6.1
Jopie
Posted · Slicing a box ends up as a brick. Cura 4.6.1
I tried to print a box for my Phase 10 cards. Found one here:
https://www.thingiverse.com/thing:2714917
But when I sliced it with Cura 4.6.1 with my default parameters, the box gets filled in with a bottom of about 1 cm. The lid ends as a brick.....
I finally sliced it with Cura 4.5, same parameters. No problem.
Is this a bug or am I missing some new parameter here?
    Posted (edited) · Slicing a box ends up as a brick. Cura 4.6.1
    I added some pictures of skewed, sliced lids, the Cura4.5 shows What it should look like, Cura 4.6.1 is the result with 4.6.1.
    Edited by Jopie
    That link isn't for the same box as you show in your images. Anyway, I sliced it fine. Can you please provide the project file ? Do File -> Save and attach the .3mf file to this thread. Thanks.
    Oops. I now remember I've looked at these parameters for the fist time a few days ago, but forgot I changed anything there.
    Thanks a lot for your very fast support.
