I dont understand either. But it’s done it multiple times now
i will force some end of rolls tonight and confirm this is consistent
I ran into similar issue when we comissioned the printer.
A good cleaning of the extruder was the only thing we did and it's working as expected now. Oddly, the extruder was perfectly clean so I can't tell you why it worked...
as an update- it appear that the firmware works by using the movement rates relative to the stepper motor at the beginning as a reference. So if there is no flow detected at the beginning, it will still continue to run. I think this is waht was happenign in my case.
A little official description on how things work, even just a few paragraphs would help a lot with fault finding- its a shame the information on how these parts work is so scarce.
Carla_Birch 114
The filament sensor is built into the printers feeders, basically you will see a little PCB and thats got a wheel on it, thats the sensor and the filament moving should turn the wheel. when the filament runs out it should be pulled past the wheel and stop in the knurled wheel before it goes past it.
So i don't see how it would work if you hold the filament from moving but then not work when it runs out past the sensor wheel.
