The two most annoying problems with my S5 Bundle
Jonas98
Posted (edited) · The two most annoying problems with my S5 Bundle
My personal day ruiner... 10 trys, no start.
3 Months everthying was great.
Now again that .....
How can Ultimker think its an good idea to put an that susceptile sensor into an "industrial" machine
The "test" says Sensor is good....
I have to print something and cant use the printer.....Thats extremly annoying
In the "best" case just a dirty printer, in the worst case an blocking Z axis.
Please fix this....
An reliable printing would be much more usefull than any cloud funktionality
Edited by Jonas98
    Posted · The two most annoying problems with my S5 Bundle
    Hi Jonas, thank you for your message. In the latest firmware update the priming sequence has been updated so it should prime less material. Obviously what it still primes does end up on the bottom of your machine but this is necessary to ensure a successful next print when you switch materials and when the Material Station automatically loads material.
    My German is a little bit rusty, but unless I'm wrong the display informs you that it couldn't complete the active leveling. Has this been resolved in the mean time? Let us know if you need any further help. Thanks,
    I priming sequence is a lttle bit better.
    But if you have to cancle the print and wait for it it is still very long.
    yes cant complete the auto leveling
    I fixed this by soldering the cables at the capazitive board and replaced the crimp conctacts at the cables.
    Till now it is working.....I hope for a long time.
    I think the leveling is too susceptible
