On 7/1/2020 at 10:03 AM, GregValiant said:Being line-to-line with the build surface size may be an issue (where 349.99 x 349.99 may not be an issue) . If you have set up for a brim/skirt/raft then that detracts from the surface size as they take up room outside the model.
Non-manifold means Cura is having issues with the model file itself. If you post the model file here someone will take a look and suggest fixes for it. A non-manifold model cannot be sliced by Cura because there are gaps in the model (it isn't water tight).
GregValiant, thank you for your input and explanation. I tried sizes even much lower than that with no success.
As for the gaps, what I am trying to print is an array of devices, but due to size constraints, they have to fit VERY close together.
Not being able to print such an array is an issue for me, and I have no problem slicing and printing the full model array with the Ender slicer. But I wanted to use the Cura because it was highly recommended. Is there any sort of override setting to enlarge the active print space to the full 350mm x 350mm size?
GregValiant 697
