Did you find a fix i have the exact same problem, please help haha thanks
- 5 months later...
Yep me to exact same issue ???? HELP and same issue on my windows 8 and Windows 10 machines... I'm thinking there's a fault with Cura now not just me....... Oh well they may loose me soon as I don't have time to waste on software that's not supported.
Â
Edited by GTRClive
SandervG 1,521
Hi @TimeLord11, thank you for your message and welcome to the community. @nallath, do you know? Thanks!Â
ahoeben 1,992
I have not used Windows 8 in a long while, but as far as I know Cura should just work on it. Unfortunately, if you download dll files and put them somewhere on your system, that gets your system in a state where we don't know what versions of what files are where, making it harder to help you. Do you still have a list of dll files you installed?
Â
It sounds like the "Visual C runtime redistributables" are corrupted and/or have mismatching versions. The Cura installer comes with these redistributables and offers to install them for you. It could be that the installer thinks a newer version is already installed on your system (especially if you make a habbit of manually downloading DLLs and putting them on your system). You could try uninstalling any and all "Microsoft Visual C++ Redistributable" from your system, and then install Cura again. NB: this may affect other applications on your system.
TimeLord11 0
It was the first time that I downloaded DLL files in order to solve something like this.
Before that I tried to re-install Cura but got error messages about the missing DLL.
I tried to ask on Facebook in a 3D printing group, but the only person who replied refused to help me when he found I still use Windows 8.1
On the site where I downloaded the files the instructions were that each 32bit version of the DLL to be copied to the folder
C:\Windows\SysWOW64, and each 64bit version of the files to be copied to C:\Windows\System32.
Â
List of the missing files is:
api-ms-win-crt-conio-l1-1-0.dll
api-ms-win-crt-convert-l1-1-0.dll
api-ms-win-crt-enviornment-l1-1-0.dll
api-ms-win-crt-filesystem-l1-1-0.dll
api-ms-win-crt-heap-l1-1-0.dll
api-ms-win-crt-locale-l1-1-0.dll
api-ms-win-crt-math-l1-1-0.dll
api-ms-win-crt-process-l1-1-0.dll
api-ms-win-crt-runtime-l1-1-0.dll
api-ms-win-crt-stdio-l1-1-0.dll
api-ms-win-crt-string-l1-1-0.dll
api-ms-win-crt-time-l1-1-0.dll
