UlrichC-DE 103
The printer as well as the MS have feeders.
The MS feeder can feed the printer. The reverse is not possible?
Do you need these two feeders to clean the printhead?
No, due to the 6-to-1 junction in the material station feeding goes only in one direction. The feeders on the printer are responsible for continuously feeding material through the print cores while the prefeeders in the material station work in steps and make sure the main feeders always get enough filament.
1 hour ago, Dim3nsioneer said:No, due to the 6-to-1 junction in the material station feeding goes only in one direction.
Thanks for the answer. This explains why he loses so much filament when changing.
Because it is due to the system.
2 hours ago, Dim3nsioneer said:As you realized there are about two meter of filament left which you can e.g. perfectly use for performing print core cleaning.
This only works with PLA 😉
12 minutes ago, UlrichC-DE said:This only works with PLA 😉
With the print core cleaning wizard, yes. But you can also do manual cold pulls by adjusting temperature manually and then you can also use other filaments.
Sure, but I count that to the things that are not fun at all.
Better to distribute the tip in the future. "Get a 3Doodler" or "Braid yourself a basket"
Regardless of it being fun or not, it can be a useful way to purpose those last pieces of filament. Or don't. That is up to the user. But it is an option at least.
I may have expressed myself indistinctly.
In my world (development and manufacturing), not having fun is having a problem.
The note is still missing that not every filament is suitable for cleaning.😉
Dim3nsioneer 551
The filament runout sensors in the Material station are just before the prefeeder in the Material Station so the remaining filament can be retracted back into the Material Station compartment.
