OK many thanks, that did the trick. No options to scale to fit that I could see but reduced the size to 198mm and it seems to have solved it.
I think that the flat object was too large to fit when taking into account the skirt/brim settings - so you were left with just the gcode from the initial slicing it did as soon as the object loaded, when it was still on its side.
This is arguably a bug in Cura... If it can't reslice the updated object, it should refuse to print/save - not just use an earlier version without telling you.
Hello I have a problem printing with this tower eifel 4 parties.Au his early prints well, after after 2 h the nozzle continues to print may be more wire exits the nozzle, I do not think his or butcher? File just Thingiverse
http://www.thingiverse.com/thing:124990
Cordially
I don't understand. Do you mean nozzle *doesn't* continue to print?
Please post a picture of the failed print.
@mark hale - Try removing brim and skirt - go to advanced settings and set skirt lines to 0.
3dcase 37
I'm not in the modern things like UM2's, but because it stays grey, pretty sure it is to big for your platform settings.
Try the "scale to fit" to button, and you see how much to big.
Perhaps (Try careful!) when it's about a few mm's,try to set your platform values a little higher .
