UlrichC-DE 114
Hello
Thank you for your answer. My question has to sound like I'm looking for what, just don't know what. Fortunately, it's not quite like that 🙂
In most cases, only a temperature resistance of 120° Celsius. For a mechanical component.
In the current case, a stable housing next to a warm high-pressure line is required. The environment is outdoor,very dirty/oily and damp. PA only is too soft.
I use ColorFabb PA-CF on other printer. This can be printed very well. The surfaces and are very good and the finishing is easy.
Unfortunately, the printer's (converted UM2) workspace is too small. I therefore print the housing in several parts. This is time consuming and does not look particularly good afterwards. It doesn't look nice afterwards. It will be painted.
On the bundle I tried to load ColorFabb XT-CF20. When choosing, I get ER64.
I don't know if it is technically possible with the material station.
If there was a material that is direct supported by the material station. I buy and test it.
If the material station is not built for abrasive filaments, I leave that.
Otherwise I can try to configure it for the material station.
I have not found information about it
Carla_Birch 116
That’s really is down to what you need it to hold up to. Is a wide range out and some are good in one and weak in another.
Eg do you need shock load, or hold up to heat. Does it need to flex a little or be ridged.
