API and changing LED color
alkekmakerspace
Posted · API and changing LED color
I have been attempting to change the color of the LEDs in my Ultimaker S5s using the API, but it never seems to work.
When I set anything other than 0 for h or s, it just dims the lights.
I get a 204 response code.
I can then do a GET request and it shows me the values that I just set, so I know the printer is getting the data.
Is this part of the API broken?
See code below that I found on the forum and changed a little.
def set_mainled(ip, h, s, v):
    api = initAPI(ip)
    # read the current LED status
    led = api.get("api/v1/printer/led").json()
    print ("current LED state: ",led)
    if h is None:
        h = led["hue"]
    if s is None:
        s = led["saturation"]
    if v is None:
        v = led["brightness"]
    # Change the LEDs
    print(api.put("api/v1/printer/led", data={"brightness": v, "saturation": s, "hue": h}))
    print("set LED state to: ",led)
    Posted (edited) · API and changing LED color
    yes 😞
    I'm still a little sad colors got left out when we build the S5, I would have much preferred colors to indicate printer-state or allowing the user to set a color for the printer.
    Edited by robinmdh
    1 hour ago, robinmdh said:
    yes 😞
    Would have been good if was color, so if eg a filament run out happened it would for eg flash an red color so it could be easy to spot. Could someone swap the led strip for a RGB one or is it a limit on the board?
    2 hours ago, robinmdh said:
    yes 😞
    Yes that's exactly what I wanted to do. When a print finished, change to a certain color, when there was an error, change to another color, etc.
    Edited by alkekmakerspace
    so did we when implementing the initial version of the digital factory, UX voted against this because it was harder to procure color LED strips that where properly white balanced so with the next printer they went with more consistent but only white LED's.
    It depends a bit on if you have a S5 with A U on the side or with an ultibot on the side, if there's an ultibot on the side the connector exists and you can just connect the led strip, AFAIK. the connector is marked as P3 in the schematic, you would have to find a common anode RGBW led strip (4 chanels of RGBW and one for the positive voltage)
    If you have an U on the side it gets more complicated:
    So the led strip used I2C but sending commands to it would be disabled in the S5 firmware. look for the ledRGBWUpdate function in the marlin firmware, this part of the software is open source and you should be able to request a copy from support!
    if you can get a similar PWM chip you could enable it https://github.com/Ultimaker/Ultimaker3/blob/master/PCB files/1548-I Ultimainboard/Schematics and layout pdf/Schematic Prints.PDF
    shows we used a PCA9632DP2 IC. you can connect it to the I2C lines via the cables going to the flow sensor, but that would likely not do for the current/voltage you need.
    Anyway this would require soldering, connecting IC's and some transistors etc.
    TL;DR
    Yes you can plug in a RGBW strip, but only if you have an ultibot on the side of your printer iso a big U.
    Edited by robinmdh
    added to the tl;dr and added quote of Carla's post, common anode not cathode... oops
    TL;DR
    Good to know. We are actually running 8 S5s with the ultibot logo. So it sounds like it might be possible to just swap the LEDs for my situation, but I'm not going to do that on relatively brand new machines. Does that then explain why the brightness of the lights changes when I attempt to change the H and S values via the API? Are those pins connected to different pins on the white LED strips?
    Yes, the API extracts the white component from the hue / saturation / brightness  and sends that to the white LED's allowing the RGB LED's to do less; So changing the saturation should have an effect on the white brightness, setting the hue should only have an effect if the saturation is not 100% or 0%, yes.
    you do need 24V RGBW led strips like these: https://www.superbrightleds.com/moreinfo/flexible-led-strip-lights-color-changing/5m-rgbw-led-strip-light-color-changing-led-tape-light-12v24v-ip20/5151/?replacement=1572  Most stips I find are the individually addressable ones these days.
    Edited by robinmdh
    added link
