XY calibration is indeed stored for a position locked pair of print-cores.
But this almost looks like the 22 mm difference Cura inserts between the positions isn't there...
The max the calibration can handle is 2.9268 mm around a center position so + or - 1.4634 mm.
To even begin to debug this I'll need more info, like the firmware version, the gcode file and the files duped to the USB stick when you select the dump logs to USB at least.
UlrichC-DE 103
This looks crazy!
In theory, XY is different for each print head combination. The values in cura the total distance. The offset on the printer makes the small compensation distances. It's definitely not 5mm.
In Cura under Machine-Settings, Printhead-Settings -> Extruder 2 you find the big "Nozzle offset X".
For me (S5) this is 22mm (distance between printhead 1 and 2). Y is 0.
Different idea:
Edited by UlrichC-DEdo you have the new firmware?
