ghostkeeper 104
Indeed if you have 0.2mm layer height with 0.16mm maximum variation, it will vary between 0.04mm and 0.36mm. If instead you'd like it to vary between 0.04mm and 0.2mm, you should set the layer height to 0.12mm, and the maximum variation to 0.08mm.
We've chosen to hold the current layer height as median on purpose, because all of the other settings will have been optimised for this median layer height when you enable it. It will then stay closer to this optimised/preferred layer height overall. It's easier to transition to Adaptive Layers that way.
DivingDuck 69
There are 3 adjustment screws for Use Adaptive Layers:
There is also a very beneficially handy plugin called Settings Guide from @ghostkeeper with a detailed description for these and most other parameters.
Xeddog 6
I know about the different settings, and I think I actually understand what they do. The bottom line is that I think the Layer Height setting in the shell section should be a hard maximum layer height limit to keep from exceeding what your nozzle is capable of. The screenshot is just an example, and frankly is probably beyond my printers capability, but it does illustrate what I am talking about. I would be attempting to smooth out the top dome part of the model without affecting the 0.2mm layer height of the body. With a maximum variation of 0.16mm, that gives me 0.04mm layers at the top of the dome which is good (at least it would be if my printer could actually do it). But the lower cylindrical body also gets the 0.16 variation in the other direction, or 0.36mm which is very NOT good even if my printer could do it with a .4mm nozzle.
