Hi Labern,
Thank you for your reply.
I have created a 3d model using Anyrail 6, i have saved it as an STL. and opened it in Cura, i have attached the STL file for you to see the model.
I'm not sure if i may need to open the model in different software to give it dimensions?
Kind regards,
Jason
Labern 775
Hi there.
You might want to have a look at the preview part in cura and look at the layer view to see what it's actually going to print. This could be due to print setting or something wrong with your model. There is also x ray view that shows up errors in your model.
Are you able to share some pictures or screenshots of your model in layer view and perhaps some info on your settings.
Project files or stl's can also help it your able to share them.
