HOTEND_OFFSET
roald
Posted · HOTEND_OFFSET
Question: how to setup an hotend offset between primary and second hotend?
I use: upgraded ultimaker original with utlimaker 2 V2.1.1 motherboard. E3d Chimera dual extruder, heatbed, reprap smart controller and Custom firmware from https//github.com/Ultimaker/UM2.1-Firmware
Already try: give in the g-code commands "M218 T1 X20 Y0" and reply it with M500 command in simplify3d machine tab. This works for me until i switch the ultimaker off and on.
Also try to change the firmware in configuration.h
Change:
#define extruder 2
#define temp_sensor_1 20
Add:
#define HOTEND_OFFSET_X { 0.0, 20.00 } // (mm) relative X-offset for each nozzle
//#define HOTEND_OFFSET_Y { 0.0, 5.00 }  // (mm) relative Y-offset for each nozzle
//#define HOTEND_OFFSET_Z { 0.0, 0.00 }  // (mm) relative Z-
This doesn't anything do i miss something?
    Posted (edited) · HOTEND_OFFSET
    you can also set the nozzle offset in Cura (and presumably simplify3d as well) that is generally what was done for the early dual hotend setups, not very pretty, I know.
    the M218 should also work though. switching back and forth with the stock implementation every layer however  is not recommended.
    it rounds floats every-time you switch AFAIK. We replaced it for the UM3 because we did use that offset for the Z but the buildplate was slowly creeping up or down when we did switches in places to test the switching bay.
    Edited by robinmdh
    10 hours ago, roald said:
    Add:
    HOTEND_OFFSET_Y has to be defined as well, it's used here (mind the #ifdef clause):
    https://github.com/Ultimaker/UM2.1-Firmware/blob/UM2.1_JarJar/Marlin/Marlin_main.cpp#L172
    The offset is not stored in EEPROM AFAIK and there's no z-offset in this Marlin version.
    But you have to fine-tune (calibrate) the values in the start-script anyway (with M218), or do you plan to customize the firmware after every nozzle change?
    oh.. i remember... 🙂
    As a rule of thumb: use only offset values that are a multiple of the step size.
    Oke i define the y-axis as well when im back home.
    But i dont get you about the nozzle change, in my mind there be no different in distance from center to center when i change the nozzle size. And cant you explain a little bit more about the ifdef clause? Or do you have a tip/website/book to learn a little but more about this?
    The whole Marlin configuration makes extensive use of the C preprocessor
    gcc documentation for #ifdef:
    https://gcc.gnu.org/onlinedocs/cpp/Ifdef.html#Ifdef
    Its working by enable this both lines Thanks for the help
    // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
    // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
    // For the other hotends it is their distance from the extruder 0 hotend.
    #define EXTRUDER_OFFSET_X {0.0, 19.70} // (in mm) for each extruder, offset of the hotend on the X axis
    #define EXTRUDER_OFFSET_Y {0.0, 0.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
        • 27 replies
