The infill will protect the top from collapse.
Support goes on the outside to help print things that stick out. There is only the ring on the side of this part that is effected but because of the shape and it doesn't stick out far I think it should be fine without support.
1
Smithy 1,144
I would print it as is :
You don't need much support, so I would give it a try to print without support.
Advanced 2
Do you think the top can be printed without support? Or will this collapse at the end of the Print?
