Thanks very much - that's really helpful. It's definitely the prime blob causing the issues. Only problem now is I can't disable it as the setting is hidden for the Ender 3.
So when you installed cura it created a seperate, local, settings folder with lots of settings in it. Actually a huge tree of folders with hundreds of files. On a PC it's in something like %appdata%/cura On linux something like ".cura" maybe. No idea about Mac.
Search through those files for ones named "Ender" or "Creality". One of those represents your printer. It probably ends with ".json". You can edit any of these and restart Cura. You can disable the prime blob in there maybe?
By the way, if you completely delete this tree of folders it's like getting a fresh install of cura and if you restart cura it will recreate them all.
Thanks 🙂 Just checked and there's nothing for 'Ender' on my whole system and I've checked every entry from 'creality' and doesn't include the prime settings. I'm on Linux atm so will find a Windows machine and try that.
Thanks again for help 🙂
There absolutely must be a file somewhere that describes your printer.
So in cura do "help" "show configuration folder". You looked in the wrong place. Here they are on linux:
/home/geo/.local/share/cura/master/definition_changes/Creality+Ender-3_settings.inst.cfg
/home/geo/.local/share/cura/master/definition_changes/creality_ender3_extruder_0+%232_settings.inst.cfg
/home/geo/.local/share/cura/master/extruders/creality_ender3_extruder_0+%232.extruder.cfg
/home/geo/.local/share/cura/master/machine_instances/Creality+Ender-3.global.cfg
/home/geo/.local/share/cura/master/quality_changes/creality_ender3_draft_%233.inst.cfg
/home/geo/.local/share/cura/master/quality_changes/creality_ender3_extruder_0_%232_draft_%233.inst.cfg
/home/geo/.local/share/cura/master/user/Creality+Ender-3_user.inst.cfg
/home/geo/.local/share/cura/master/user/creality_ender3_extruder_0+%232_user.inst.cfg
Note that you can delete that whole cura tree and the next time you run cura it will recreate it.
On 8/17/2020 at 11:46 PM, RichL said:Thanks very much - that's really helpful. It's definitely the prime blob causing the issues. Only problem now is I can't disable it as the setting is hidden for the Ender 3.
You probably haven't made all options visible... there are many many options...
Scroll to "Buildplate adhesion"... if you don't see the "prime blob" setting, hoover to the "Buildplate adhesion"-bar and there appears a cogwheel... press the cogwheel and search for "blob"...
Edited by Mari
gr5 2,070
getting max volume out of cura
set "travel avoid distance" to zero.
disable brim and skirt both!
disable prime blob
more tips/details here:
