tinkergnome 927
16 hours ago, bisdak said:I have set my printer build X=235 Y=235 but my 200x200 image doesn't fit.
The question is... how have you done this and for which printer definition? Can you elaborate a bit?
One possible reason: If there are "disallowed areas" defined (visualized in dark grey on the build platform) those have to be changed as well.
GregValiant 1,318
It should fit. If you have a 10mm skirt 10mm away from the 200 image it wouldn't slice but the image itself should fit. A screen shot of the Cura build plate with the image on it would help.
