Firmware update on Ultimaker 3 Extended
BugMeYetAgain
  • 3 weeks later...
Posted · Firmware update on Ultimaker 3 Extended
I think you might have a corrupt USB stick or download is most likely but your firmware is quite old so you might want to use the recovery image to cleanly install the version you want.
have a look here: https://support.ultimaker.com/hc/en-us/articles/360011587199?download=%2Fen%2Fresources%2F23129-updating-the-firmware
and alternatively you can get https://software.ultimaker.com/releases/firmware/stable/5.2.11.20190503/recovery-5.2.11.20190503.img and follow this guide https://community.ultimaker.com/topic/20024-recovering-a-bricked-um3/?do=findComment&comment=19989
  • 1 month later...
