I am seeing the exact same thing on an Ultimaker 3. It was printing beautifully and then suddenly started jamming. I did all the same thing you listed, new tubes, new print core, cleaned the feeder multiple times only to have it repeatedly fail. Eventually I noticed the same thickness of the filament as your photo. I just logged in to see if there was a suggested solution for this. I’m going to replace the front fan and will update after testing.
In my case it turns out it was a failing front fan. It was still revolving, but at a lower speed insufficient to cool the printheads.
Thanks for the feedback!
Yes the front fan is very important to cool the upper part of the printcore.
Agreed! Some little strings of filament can get caught up in there and make it stop spinning, or spin too slow. It is also possible that by an unfortunate event that the cables got pinched somewhere. But usually it is some debris in between the blades.
UlrichC-DE 108
I think the front fan is responsible for this. The side fans are for cooling the workpiece.
