I am having a similar issue and need help.
i have a custom printer, Core X/Y with a Kraken hot end and the dis allowed ares are all wrong.
the issue is in the custom and or the linked fdmprinter json there is no defined disallowed area to remove.
I am not sure where to look next. the last pic is what it should look like
print area is from x5 to x300 and y0 to y330
Edited by HtRabbit
additional info
Mari 27
Changing Buildplate dimensions in Cura do not change disallowed areas... There are more topics on this forum about this subject...
In the folder /resources/defenitions/ you can find a "yourprinter".def.json file you can edit to change the disallowed areas, or maybe you can create a complete new printer (haven't tried this)...
Buizel 0
Yes, that did it for me. I went to that location, removed "machine_disallowed_areas", and re-opened cura. The non-printable areas are gone and I can slice larger models in peace again. Thanks!
