This is our bad (bed, heehehe get it?). We switched all the build plates to 3mf to make it the cura image smaller, but we didn't save this one correctly.
It has been fixed for 4.7.1, which should be out anytime now.
Ok, Thank You. I'll keep a eye out on the update
It's available now.
GregValiant 1,330
It looks like the cube is sitting on the build plate correctly. That other vertical shape is a definite oddity. In the second image it almost looks like a shadow of the cube and the Z axis. Does it slice OK?
If worse comes to worst you could mount the printer on a wall to keep the Z axis aligned with the software. Drywall screws would probably be OK. They should be the store-bought kind though. Printed ones just don't last.
mazman22 0
The cube was just for reference. If anything is placed behind that vertical oddity, it will not print
