I'm not sure if FrankCisco is having the same issue I am, but I can't open the DMG. I get an error telling me there's 'no mountable file system'. I had the same problem the day Cura alerted me of the 4.7.1. I downloaded again today to see if anything had changed.
I'm running this on an older MacBook that's still running El Capitan, so that could be part of the issue, but had no problem with 4.7.
gr5 1,514
There's really not much difference between 4.7.0 and 4.7.1. 4.7.0 makes you click on something at startup the very first time you run cura. A security warning. You've already done that so now the versions are the same for you. I'm still on 4.0.0 and it works great. I have encountered zero bugs.
Anyway, to get help, please be more specific. Does it fail when you launch Cura or when you install? What error does it get? What behavior? I'm positive that Cura was tested on several Macs before release so the software engineers are going to need a little more information.
