Thanks so much, Smithy.
You have put my mind more at ease. I guess the adage that experience is expensive is true. Guess my friend is about to get an unexpected donation of 6 rolls of 1.75mm filament.
Can you suggest a decent filament for the budget constricted?
Smithy 1,145
Ultimaker printers are made for 2.85mm filament, so out of the box and without replacing some parts it is not possible to print with 1.75mm filament. It is not only the feeder, which could work if set a high tension, but also the Bowden tube and the hot end itself is too big for 1.75. The problem can be, that hot melted material climbs up in the hot end and blocks and clogs there everything.
It can work if you have luck, but as you see you have a lot of problems. So buy the filament you need 2.85 and you should be fine.
