Dim3nsioneer 557
You can change the theme in the Cura configuration. There is a light and a dark colorblind theme too there.
Torgeir 248
Hi there,
As this one may be hard to find, -you find it under general in the configuration menu and you have to select "Theme:" then select Ultimaker.
Then you will see the different settings.
This one need a restart of Cura.
Thanks
Torgeir
