Hi zolcost1,
Just an observation, -looks like the X stepper is loose (the right one) it looks a little tilted up at the left side and the belt vibrate a lot on the right side when happening.
Thanks
Torgeir.
Edited by TorgeirSpelling.
Hi zolcost1,
Thanks
Torgeir.
Edited by TorgeirInteresting. Maybe. Or maybe it's just vibrations because the stepper vibrates strongly when it skips steps.
Thanks! Turns out I just had to oil the rods and it's printing fine again.
gr5 2,210
I fixed someone's printer that was very similar to this. It was friction on the larger diameter rods. It took me a while to figure it out. I just had to start taking it apart until I found the bearing that wouldn't slip. It only took maybe 10 minutes?
First push the head around with power off and confirm that there is high friction. Try some oil on all 6 rods (or at least the 3 X-rods).
Then next step is to pop out the 2 rods through the head - they pop out of the slider blocks - after all 4 are popped out, rotate the head 45 degrees and the head and rods can be lifted up out of the printer. Check that they slide nicely.
Next is to loosen the 4 pulleys on the X axis and move the sliding blocks separately to see if one has high frictioner and the other low.
For me it was so bad I needed hammers and vices and such and I had to remove the sleeve bearing from one of the slider blocks. It doesn't look as bad for you.
