Hi Torgeir
Yes it is an Austrian company ( I am from Austria) so would be a good combination 🙂
Thanks for the hint, will try it. I have no overhangs or bridges in the model, so should be possible.
Hi Torgeir
Hi Folks - could anyone get good printing Parameters with NX2 - for me the layer adhesion is allways very bad.
Luckily i have one use case were i have to "peel" it from a silicon cast so its ok here but for all other uses.....
(UM S5 Firmeware 8.1.1.; Cura 5.3)
Torgeir 228
Hi Smithy,
Very interesting this one, -a German made filament with European food and Toy "Certification"..
Since you discover poor layer addition, I'd try using no fan and draft shield (under experimental in Cura). 🙂
Good luck
Thanks.
Torgeir
