Problems with UM2 again.
naz72
Posted · Problems with UM2 again.
My replacement UM2 was working flawlessly for some time, than I decided to try using the flexible PLA, which worked for some time and I printed a couple of designs fine.
A couple of days later I came back & tried printing & realized my extruder was blocked.
Flexible PLA is very nice but it sticks too well to the bed & you actually need to heat the bed a little to get it off, unlike PLA where its easy to remove onces it cools down. The other problem is that it's too sticky it blocks the extruder and its a pain to get it off.
So I tried a couple of times to clean it & it worked a little & than again stopped.
Now I was trying to heat the head to 250 hoping it might help and suddenly the ultimaker crashed with the ultimaker logo half showing on the LCD, so I switch it off from the back & now it won't come on at all, so it seems dead.
I contacted Sander on the 10 & 11th of December via PM asking for spare parts back when the extruder was blocked but I did not receive any reply until this day.
Now since the UM2 is completely dead I need to know how to send it back for replacement, or I don't even mind replacing the parts myself as long as I can order them.
They only sell parts for the original UM.
Hope someone from UM2 can contact me for help.
Naser
    Try disconnecting USB cable if connected. Then disconnect power cable from home power. Leave disconnected for a very long time - until the blue lights goes off. 20 minutes for me! If you turn on the UM2 while the "brick" is unplugged you should be able to get the light to go off in one second instead of 20 minutes.
    Then turn off UM2, plug in the power brick and turn it back on.
    Some power bricks have circuitry that won't reset until you power cycle them.
    i dont think this is the same situation.
    but when i plugged in my ultimaker2 with usb. i started cura and clicked update firmware... of course my cura was still set for ultimaker 1 and uploaded the firmware for the um1 to my um2... that really shut down the whole printer... dead as a doodoo.
    so i changed my cura to ultimaker2 and then reconnected usb cable and reinstalled the correct um2 firmware... then restarted and worked perfect !
    maybe worth checking which firmware you loaded ?
    Ian :-)
    No lights? No fans? Nothing? Not even a blue light on the power brick? It's starting to sound like your power brick is broken. Or maybe the electrical outlet you plugged it into.
    Hi gr5,
    Only the blue light on the brick is on, the rest is completely dead. I tried everything you can think of but still no life in my printer.
    If it were me I would take the 2 screws off the bottom cover and remove it. Then trace the power cord and power switch and make sure when the power switch is on the power gets past the switch. I would test this using a meter. Then I would trace this signal to the main voltage regulator - a large part with 3 large pins. I would check to make sure the part generates 12V. But truly the problem is probably before this part because I think the 19V goes directly to the rear fan and so if the rear fan doesn't spin then something VERY SIMPLE is broken. I think. Possibly the switch. More likely a cable or connector right there where the power comes in.
