Thank you you for the tip, I will give it a go and will be heading off to watch your video right after this is sent. I think that I should grab some IPA and give the glass a good wipe and polish with a clean paper towel. I did do a bed levelling last night and that did help with the under extrusion issue. After levelling the first layer of my print looked great, the second layer is when everything peeled off of the plate and remained on the nozzle.
Yes, in my experience cleaning with window-cleaner sprays destroys bonding. Just like any soap would. It seems they all leave traces of soap on the glass.
I clean with isopropyl alcohol to remove grease, and then a couple of times with pure warm tap water only.
So our company prints exclusively in Poly Carbonate which is one of the hardest things to get to stick.... but I have had only 1 failed print!
My routine is after every print I clean the glass with rubbing alcohol and one of those blue paper shop towels (they don't lint), making sure to turn the towel over and inside out several times to ensure I get the glass CLEAN!
Then before printing while the glass is COLD apply a thin even layer over the entire build plate (or at least the area of your print plus some).
Then just let the printer run and do it's thing.
After the print is done let it get completely cool and you should be able to remove it will little to no issues. By letting it cool completely the plastic shrinkage breaks the bed adhesion for you so you don't have to hardly pry on it at all.
Rinse and repeat!
Smithy 1,145
I clean my glass plates with soap and water. After drying I wipe the plate with alcohol.
But I apply always a very thin layer if glue too. It is much safer that everything sticks really well.
I made a short video, because I think most people use the glue stick in a wrong way.
