In winter it might work, in summer I doubt it. And not if in direct sunlight behind a window. Standard PLA will for sure deform in a car left in the sun, even in mild spring or autumn weather. (Don't ask how I know this... :-) So if tough PLA is similar, then that will happen too.
Also think about where the lamps will be: on a ceiling is hotter than on the floor, and above a radiator could be quite hot too.
Do a few tests, and try them in the worst places, and then add enough margin.
Smithy 1,141
It is the same as PLA, so I would not use it for a lamp.
https://support.ultimaker.com/hc/en-us/article_attachments/360010175560/TDS_Tough_PLA_RB-en.pdf
RudydG 62
I use this a lot! perfect product for my mechanical parts. Although heath resistance is not high. I would say, dont go above 50 degrees celsius.
