Posted · bars fell out on Ultimaker 3
It is quite unique that it fell down completely. I recommend you get in touch with your reseller. It looks like the slider blocks that usually hold the axles came loose and lost grip. This can happen when the inside of the chamber collects too much heat, or when they have a production/material error and they break. If the latter even happens, it is usually only one. So all 4 breaking is quite unique. Unless you enclosed the entire frame, in that case I recommend you to be careful and be cautious of the internal temperature. Anyway, a reseller should be able to provide you with new slider blocks and instructions on how to install them.
