On 11/12/2020 at 3:25 PM, gr5 said:I have ubuntu. So you don't exactly "install" it as it's an "appImage" file which is already executable. You do however have to set the executable bit. You can google that but I'll try a brief explanation:
I'm sure there is a GUI way to do this but I don't know it.
Open a terminal window. Navigate to where Cura was downloaded to. For Chrome and for me it was just this:
cd Downloads (case sensitive)
Then find the file
ls *AppImage (this is case sensitive)
Then use chmod to set the executable bit (in windows, anything that ends ".exe" is executable - in linux you have to set a bit - it's not part of the file name, it's a bit). The "774" sets the executable bit. But for you - not for all users.
chmod 774 Ultimaker_Cura-4.7.1.AppImage
In this last example you can just type up to the "Ult" and then hit tab key for linux to fill in the rest (if it's a unique file name - read about tab key and linux as it's incredibly useful).
You only need to run:
chmod +x Ultimaker_Cura-4.7.1.AppImage
The +x is for setting it as executable.
Alternatively, you can also press right mouse on the file, go to properties. In that menu there should be a checkbox that states something like "Allow executing file as program"
gr5 2,194
Then find the file
