GregValiant 697
I want you to know @Framar that if I would have worked harder in 9th grade typing class I'd have gotten here first.
Yes, you can use "Support Blockers". Scale them, move them into position, set the "Per Model Settings" and "Modify Settings for Overlaps". Select the settings you want to alter (not all settings are available but # of walls is). There is a plugin for cylindrical support blockers if the rectangular ones don't work for you.
Framar 24
You can use support blocker and assign them more walls.
