Yes, it looks more complicated on the first look as it is actually. And it is nice, that you can fire the api calls directly from the webpage, so no need to write an external script or so for some simple things.
1
Smithy 1,145
You can remove the material manually via the printer api:
http://<PRINTER-IP>/docs/api/#/Materials
Read the upper part with authentication, you need to create an user first.
eschwartz96 2
Well if I would have just scrolled down a little farther..
Thank you for the help! First time messing around with the API's and it went smoothly. 🙂
