Thanks, this is what I was looking for! Can you link the page where this "Property" are documented?
16 hours ago, Fabiuz said:Thanks, this is what I was looking for! Can you link the page where this "Property" are documented?
Unfortunetly there is no real documentation for these scripts or plugins ... If you need some informations you must go directly in the source code . For this type of informations I'm reading directly the fdmprinter.def.json Jason file https://github.com/Ultimaker/Cura/blob/master/resources/definitions/fdmprinter.def.json
You can find in this file every parameters associaed with a printer and for each parameters existing proterties.
This is a bit more readable version of the same file:
nallath 1,063
In the case of layer_height, which is a global setting, you need to do it like this:
