Cura often switches my profile settings between restarts
Litka
Posted · Cura often switches my profile settings between restarts
Hello everyone!
I have a problem with profiles in Cura.
Cura settings are jumping back and forth between restarts. Also it seems like they are switched as groups to previously seen values like Cura under the hood actually switches quality profiles or quality changes, though on the surface Cura shows that this is still the same profile. Normally Cura should maintain settings, not switch them randomly at restarts.
Here is a video where I restart Cura a few times and settings switched back and forth.
My current Cura version 4.8. I don't remember when exactly the problem started to happen, maybe since version ~4.3-4.7. I haven't printed much since, waiting for the problem to be fixed with the each next release.
I also tried turning off all non-bundled plugins (including plugins related to profiles), but the problem is still happening.
I suppose my profiles might be corrupted.
Do you have an idea what might be wrong with my profiles and how can I fix it?
If possible, I would rather not create all my quality profiles and material profiles setting by setting from scratch... But I don't mind deleting some files in configuration folder or replacing a string or two in each profile file.
Thank you kindly for reading this long post.
    3 hours ago, nallath said:
    Could you share the log files? I think it might have something to do with rights.
    Sure, here are log files.
    cura.log was recorded during:
    1. Starting Cura.
    2. Me writing a new value to some setting.
    3. Closing Cura.
    4. Starting Cura and me seeing that the setting is different from what it was.
    cura.log stderr.log stdout.log
    17 hours ago, nallath said:
    I don't see anything that really pops up from the logs. Could you create an issue on github and also share your configuration folder?
    Okay. Thanks for checking the logs.
    I think I can share my configuration folder. But is it safe? My configuration folder probably contains passwords for my ultimaker account and "Octoprint connection" plugin. What should I do to make sure that my passwords in any form (open, hashed or somewhere cached) will not leak?
    You can remove the keys from the preferences by hand if you want to.
    Okay, I created this issue with attached configuration folder: https://github.com/Ultimaker/Cura/issues/8907
    It's a very good bug report! Thanks!
    • Thanks 1
