Trying to create a new custom profile for a new printer. Having issues with machine qualities...
mrdindon
Posted · Trying to create a new custom profile for a new printer. Having issues with machine qualities...
So I got a SecKit SKGo2 printer. I've being playing with Cura definitions to create a custom profile for it and got something working at one point by copying data from the Creality Ender3 pro and modifying it from there. But I was never able to create custom machine qualities (Ie .: Extra Fine, Fine, Normal,Draft, etc..)
So what I did is to strip down my config to the minimum and tried to add qualities from there, but without success.. Cura is not reading / adding the quality file I made even after deleting appdata/roaming/cura and appdata/localdata/cura. If anyone could help me that would be nice :)
Please remember this is a stripped down version just to try to make de qualities to work
definition file : SecKit_SKGo2.def.json
    "name": "SecKit_SKGo2",
    "version": 2,
    "inherits": "fdmprinter",
    "metadata": {
        "visible": true,
        "author": "SecKit",
        "manufacturer": "SecKit",
		"file_formats": "text/x-gcode",
        "platform": "SecKit_bed.stl",
		"platform_offset": [-65, -32, -40],
        "has_machine_quality": true,
		"machine_extruder_trains": {
            "0": "SecKit_SKGo2_extruder"
extruder file : seckit_skgo2_extruder.def.json (directly copied from the ender3)
    "version": 2,
    "name": "Extruder 1",
    "inherits": "fdmextruder",
    "metadata": {
        "machine": "SecKit_SKGo2",
        "position": "0"
    "overrides": {
        "extruder_nr": { "default_value": 0 },
        "machine_nozzle_size": { "default_value": 0.4 },
        "material_diameter": { "default_value": 1.75 }
and my quality file located under quality/SecKit_SKGo2/draft.inst.cfg
[general]
version = 2
name = SK_DRAFT
definition = SecKit_SKGo2
[metadata]
setting_version = 15
type = quality
quality_type = normal
weight = 0
material = generic_pla
[values]
layer_height = 2.2
wall_thickness = 1.05
top_bottom_thickness = 0.8
infill_sparse_density = 20
speed_print = 80
speed_layer_0 = =round(speed_print * 30 / 50)
speed_topbottom = =math.ceil(speed_print * 20 / 80)
cool_min_layer_time = 5
cool_min_speed = 10
Running Cura that way and adding the printer, I only see a quality called "Fine" thats has nothing to do with the dedicated quality I created...
And if I remove the ("has_machine_quality": true,), I get the defaults one located at the quality root folder.
Then, I tried to duplicate the ABAX PRi3 profile but thats event worst because I just don't understand how the custom qualities are applied for that printer since there is no reference at all to "has_machine_quality" and it can still go read the specific qualities for that printer anyone just to confuse me a little bit more. . .
Any idea ?
Also, nothing specifically wrong (at least from my perspective) in the cura log file
2020-11-22 13:21:51,731 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
2020-11-22 13:21:51,758 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
2020-11-22 13:21:51,778 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
2020-11-22 13:21:51,796 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
2020-11-22 13:21:51,814 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
2020-11-22 13:21:51,833 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
2020-11-22 13:21:51,870 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
2020-11-22 13:21:51,889 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
2020-11-22 13:21:51,921 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
2020-11-22 13:21:51,939 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
2020-11-22 13:21:51,959 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
2020-11-22 13:21:51,985 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
2020-11-22 13:21:52,004 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
2020-11-22 13:21:52,023 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
2020-11-22 13:21:52,043 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
2020-11-22 13:21:52,064 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
2020-11-22 13:21:52,086 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
2020-11-22 13:21:52,103 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
2020-11-22 13:21:52,119 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
2020-11-22 13:21:52,145 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
2020-11-22 13:21:52,163 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
2020-11-22 13:21:52,207 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
2020-11-22 13:21:52,230 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
2020-11-22 13:21:52,252 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
2020-11-22 13:21:52,274 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
2020-11-22 13:21:52,337 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-22 13:21:52,343 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-22 13:21:52,349 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-22 13:21:52,353 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-22 13:21:52,358 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-22 13:21:52,365 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-22 13:21:52,370 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-22 13:21:52,376 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-22 13:21:52,390 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
2020-11-22 13:21:52,413 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
2020-11-22 13:21:52,434 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
2020-11-22 13:21:52,462 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
2020-11-22 13:21:52,491 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
2020-11-22 13:21:52,508 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
2020-11-22 13:21:52,535 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
2020-11-22 13:21:52,552 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
2020-11-22 13:21:52,579 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
2020-11-22 13:21:52,604 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
2020-11-22 13:21:52,623 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
2020-11-22 13:21:52,886 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
2020-11-22 13:21:52,903 - INFO - [Thread-1] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
2020-11-22 13:21:52,931 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
2020-11-22 13:21:53,881 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
2020-11-22 13:21:53,954 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
2020-11-22 13:21:53,979 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
2020-11-22 13:21:54,003 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
2020-11-22 13:21:54,023 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
2020-11-22 13:21:54,045 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
2020-11-22 13:21:54,064 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
2020-11-22 13:21:54,083 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
2020-11-22 13:21:54,103 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
2020-11-22 13:21:54,120 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
2020-11-22 13:21:54,137 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
2020-11-22 13:21:54,161 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
2020-11-22 13:21:54,179 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
2020-11-22 13:21:54,197 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
2020-11-22 13:21:54,216 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
2020-11-22 13:21:54,238 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
2020-11-22 13:21:54,254 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
2020-11-22 13:21:54,275 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
2020-11-22 13:21:54,294 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade462to47
2020-11-22 13:21:54,310 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade47to48
2020-11-22 13:21:54,328 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
2020-11-22 13:21:54,360 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
2020-11-22 13:21:54,397 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
2020-11-22 13:21:54,418 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
2020-11-22 13:21:54,424 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [432]: Loading all plugins took 3.9088993072509766 seconds
2020-11-22 13:21:54,449 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
2020-11-22 13:21:54,484 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [175]: Checking and performing updates took 0.03406047821044922
2020-11-22 13:21:54,493 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [226]: The preferences file cannot be found or it is corrupted, so we will use default values
2020-11-22 13:21:54,500 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [235]: The preferences file 'None' cannot be found, will use default values
2020-11-22 13:21:54,954 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [361]: Loading metadata into container registry took 0.20829272270202637 seconds
2020-11-22 13:21:54,965 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
2020-11-22 13:21:54,973 - INFO - [MainThread] cura.CuraApplication.run [782]: Initializing machine error checker
2020-11-22 13:21:54,979 - INFO - [MainThread] cura.CuraApplication.run [787]: Initializing machine manager
2020-11-22 13:21:54,987 - INFO - [MainThread] cura.CuraApplication.run [792]: Initializing container manager
2020-11-22 13:21:55,587 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
2020-11-22 13:21:55,643 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.8.0\resources\themes\cura-light\theme.json
2020-11-22 13:21:56,203 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [246]: Loaded theme C:\Program Files\Ultimaker Cura 4.8.0\resources\themes\cura-light
2020-11-22 13:21:57,939 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [340]: Creating post processing plugin view.
2020-11-22 13:21:57,956 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: ChangeAtZ
2020-11-22 13:21:57,960 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: ColorMix
2020-11-22 13:21:57,964 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: DisplayFilenameAndLayerOnLCD
2020-11-22 13:21:57,968 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: DisplayProgressOnLCD
2020-11-22 13:21:57,970 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: FilamentChange
2020-11-22 13:21:57,972 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: InsertAtLayerChange
2020-11-22 13:21:57,979 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: PauseAtHeight
2020-11-22 13:21:57,983 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: RetractContinue
2020-11-22 13:21:57,985 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: SearchAndReplace
2020-11-22 13:21:57,994 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: Stretch
2020-11-22 13:21:57,998 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: TimeLapse
2020-11-22 13:21:58,000 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: UsePreviousProbeMeasurements
2020-11-22 13:21:58,399 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [350]: Post processing view created.
2020-11-22 13:21:58,615 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-11-22 13:21:58,622 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-11-22 13:21:58,629 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-11-22 13:21:59,605 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
2020-11-22 13:21:59,775 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2020-11-22 13:21:59,785 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.8.0/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:143: TypeError: Cannot read property 'hasRemoteConnection' of null
2020-11-22 13:21:59,838 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.8.0/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:234: TypeError: Cannot read property 'activeStack' of undefined
2020-11-22 13:21:59,844 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.8.0/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:233: TypeError: Cannot read property 'isEnabled' of null
2020-11-22 13:21:59,928 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
2020-11-22 13:21:59,982 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [117]: Creating model checker view.
2020-11-22 13:21:59,997 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [126]: Model checker view created.
2020-11-22 13:21:59,998 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
2020-11-22 13:22:00,100 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [544]: Requesting [updates] metadata from server.
2020-11-22 13:22:00,107 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [124]: No auth data to retrieve the access_token from
2020-11-22 13:22:00,113 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
2020-11-22 13:22:00,129 - DEBUG - [MainThread] cura.CuraApplication.run [833]: Booting Cura took 10.57846736907959 seconds
2020-11-22 13:22:00,129 - DEBUG - [Thread-2] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
2020-11-22 13:22:00,137 - DEBUG - [Thread-2] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
2020-11-22 13:22:01,354 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
2020-11-22 13:22:01,361 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [38]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
2020-11-22 13:22:01,367 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [62]: Updating QualityProfilesDropDownMenuModel.
2020-11-22 13:22:01,371 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [74]: No active GlobalStack, set quality profile model as empty.
2020-11-22 13:22:01,893 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
2020-11-22 13:22:01,910 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
2020-11-22 13:22:01,917 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 27.20.100.8681
2020-11-22 13:22:01,924 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
2020-11-22 13:22:01,930 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) UHD Graphics 605
2020-11-22 13:22:01,935 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
2020-11-22 13:22:01,942 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\default.shader]...
2020-11-22 13:22:01,972 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\selection.shader]...
2020-11-22 13:22:01,997 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\select_face.shader]...
2020-11-22 13:22:02,022 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\default.shader]...
2020-11-22 13:22:02,048 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\composite.shader]...
2020-11-22 13:22:02,090 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\overhang.shader]...
2020-11-22 13:22:02,131 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\striped.shader]...
2020-11-22 13:22:02,169 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\transparent_object.shader]...
2020-11-22 13:22:02,199 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\striped.shader]...
2020-11-22 13:22:02,239 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\xray.shader]...
2020-11-22 13:22:02,262 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\xray_composite.shader]...
2020-11-22 13:22:02,317 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\platform.shader]...
2020-11-22 13:22:02,352 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\xray.shader]...
2020-11-22 13:22:06,694 - INFO - [MainThread] cura.CuraApplication.writeToLog [596]: User accepted the User-Agreement.
2020-11-22 13:22:14,859 - INFO - [MainThread] cura.Settings.MachineManager.addMachine [397]: Trying to add a machine with the definition id [SecKit_SKGo2]
2020-11-22 13:22:15,427 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for SecKit_SKGo2 took 0.02141261100769043 seconds.
2020-11-22 13:22:15,547 - WARNING - [MainThread] cura.Settings.CuraStackBuilder.createExtruderStackWithDefaultSetup [115]: Could not find preferred nozzle . Falling back to empty.
2020-11-22 13:22:15,559 - WARNING - [MainThread] cura.Machines.MaterialNode.preferredQuality [57]: Could not find preferred quality type normal for material generic_pla_175 and variant empty_variant, falling back to empty_quality.
2020-11-22 13:22:15,573 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [194]: Extruder[SecKit_SKGo2_extruder #2] added to [SecKit_SKGo2 #2] at position [0]
2020-11-22 13:22:15,580 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [SecKit_SKGo2]
2020-11-22 13:22:15,588 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [189]: Extruder [SecKit_SKGo2_extruder #2] has already been added to this stack [SecKit_SKGo2 #2]
2020-11-22 13:22:15,597 - INFO - [MainThread] UM.Logger.info [122]: Initializing Active Machine...
2020-11-22 13:22:15,634 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2020-11-22 13:22:15,663 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.8.0/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:233: TypeError: Cannot read property 'isEnabled' of null
2020-11-22 13:22:15,675 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2020-11-22 13:22:15,681 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2020-11-22 13:22:15,689 - INFO - [Thread-3] STLReader.STLReader.load_file [52]: Using NumPy-STL to load STL data.
2020-11-22 13:22:15,711 - DEBUG - [MainThread] cura.UI.WelcomePagesModel.goToNextPage [134]: Page [machine_actions] should not be displayed, look for the next page.
2020-11-22 13:22:15,727 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name SecKit_SKGo2 in list of firmware to check.
2020-11-22 13:22:15,746 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [556]: Calculating normals took 0.021430253982543945 seconds
2020-11-22 13:22:15,753 - DEBUG - [Thread-3] STLReader.STLReader._read [104]: Loaded a mesh with 270042 vertices
2020-11-22 13:22:15,798 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [155]: New error check scheduled.
2020-11-22 13:22:15,993 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [62]: Updating QualityProfilesDropDownMenuModel.
2020-11-22 13:22:16,004 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
2020-11-22 13:22:16,061 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\default.shader]...
2020-11-22 13:22:16,086 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.8.0\resources\shaders\grid.shader]...
2020-11-22 13:22:16,217 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [62]: Updating QualityProfilesDropDownMenuModel.
2020-11-22 13:22:16,231 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
2020-11-22 13:22:17,064 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [214]: Error check finished, result = False, time = 1.3s
2020-11-22 13:22:29,976 - DEBUG - [MainThread] cura.AutoSave._onTimeout [59]: Autosaving preferences, instances and profiles
    8 hours ago, mrdindon said:
    Is it a Cura 4.8 bug ?
    It is far more likely a bug in the tutorial.
    I have not checked the entire thing, but the first thing that strikes me is that they seem to be using Cura 3.6 and not telling you. Profiles have a way of saying what version of Cura they are for. The "setting_version" needs to match whatever the setting version is in the other profiles that come with the version of Cura you are running. For Cura 4.8, that setting_version needs to be 16, not 12.
    Does setting_version needs to be in the "quality" config files only ?
    Should the "version" variables from the definition, extruder, variants should also match "16" ?
    So I tried redoing it with "setting_version" set at "16" in the quality file with the exact same result. Cura opens and randomly apply a quality from the generic ones and doesn't show any other qualities from rather the generic or the custom ones... So close yet so far... I can't figure it....
    Definition:
        "name": "seckit_skgo",
        "version": 2,
        "metadata": {
            "visible": true,
            "author": "seckit",
            "manufacturer": "Seckit",
                "0": "seckit_skgo2_extruder_0"
            "has_materials": true,
            "has_variants": true,
            "variants_name": "Nozzle Size",
            "preferred_variant_name": "0.4mm Nozzle",
            "preferred_quality_type": "standard",
            "preferred_material": "generic_pla"
    extruder:
        "version": 2,
        "metadata": {
            "machine": "seckit_skgo",
            "position": "0"
    variant :
    [general]
    name = 0.4mm Nozzle
    version = 4
    definition = seckit_skgo
    [metadata]
    setting_version = 16
    type = variant
    hardware_type = nozzle
    [values]
    machine_nozzle_size = 0.4
    quality:
    [general]
    version = 4
    name = Low Quality
    [metadata]
    type = quality
    quality_type = low
    variant = 0.4mm Nozzle
    [values]
