Here is photo of the 3d prints. They're same thickness. Even though they're both 90% infill the left parabolic curve is 50% heavier than the right triangle. I can only think that the nozzle need cleaning when I printed the triangle. The volume of the parabolic shape is 18% less than the triangle which feels lighter and a bit less solid.
I was hoping to balance these on a see saw (per archimedes method of mechanical theorems on wikipedia) as a math toy and so the weight needs to be accurate.
I'll try reprinting the triangle.
So my question is how accurate should I be able to get the weights if the print density is set at 90%?
Perhaps I'd be better of with some other material than PLA - they shapes are so light anyway but its a proof of concept and so I'd like to get it to work.
geert_2 460
I think you will need to provide images of the models, of the cross sections, and of the layer-views while slicing, and project files and parameters. Otherwise it would just be wild guessing.
