Ultimaker Cura create gap when slicing
DavidN111
Posted · Ultimaker Cura create gap when slicing
Hello,
I am using Cura to slice my model before printing on Ender 3. I'm trying to prepare a model founded on Thingiverse but I have a problem with it.
After slicing, I've got a gap between 2 parts of the model but when I check before slicing or in Fusion 360, there is not gap.
Is there a configuration to do to adjust this ? Thanks
    That's almost surely a problem with the model.  Did you try printing it?  It might work okay - the lines might be close enough to bond.  Look at it in layer view and lower the slider until you can see that slice/opening.
    You can play with the cura "mesh repair" features or you can try sending it through a free repair service.  But I suspect that tiny air gap is really there in the model and so the repair services might not fix anything:
    netfabb free repair service is here (you have to create a free account first):
    https://service.netfabb.com/login.php
    Here's another service - drag and drop mesh repair service:
    https://3d-print.jomatik.de/en/index.php
    Thanks for your help, I tried to print it and had the issue.
    I used netfabb repair service and seem to be good on Cura ! I will try to print it soon. Thanks !
